The is a drain back grove in the cap. Not common to plug-up on a 1937.
Excessive bearing clearence can cause some leakage.
What I did on my '39 years ago was cut a small grove in the lower bearing from the center grove in the insert to the front of the engine. This lessens the oil pressure to the rear half of the bearing,
I found this tip in the book "Cast Iron Wonder" It said to cut the grove with two hack saw blades held side by side about .020 " deep Worked well and drove the car many thousands of miles on the interstate.
