Hello I have a 216 all original that runs and after a little while it turns off until it cools off it still has fuel in the pump and in the filter and even when I put gas in the carb it wont start any help? Thanks
Try a new coil!
i agree with Chevy 1937.
So, in addition to the coil, check the following;
a. Wire from coil to the distributor
b. Points (with the switch on use a screwdriver at the points to see if you're getting spark
c. Condensor (just install another one)
It does sound like an ignition problem.
Good luck,
Thanks I will try all this over the weekend.
I would also try hotwiring it and see if you have bad contacts in your ignition switch. The same thing happened to me and a new switch fixed the problem after I had tried all of the suggestions above.
"Never give up" Louis Chevrolet
