Posts: 12 |
HELP! Would someone familiar with a 1939 GMC COE radiator set-up please respond. I am guessing the Chevy COE would be similar. I have a problem with the radiator fill because I am building from scratch and have never seen what is supposed to have been. Thanks Mike Denbar
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
Mike, I don't know if this helps or applies. On the '41-'46 Chevy C.O.E., The radiator has a smooth neck. A short length of straight hose connects it to the filler neck (with cap). A bracket or clamp secures the metal neck and cap to the firewall. I'm not looking at this setup at the moment so I am going from memory. I never understood why the extra upward extension was needed.
Posts: 3,292 |
mike denbar , sent you a PM with friend who has a 39 coe . Hope he can help you out. mike lynch.........................
Posts: 12 |
Mike, Thanks, but mine is set up differently. I guess the radiator that was given to me (did not come with the truck)went to a truck that had the cowl flip up like a hood. Mine does not do that. I figured out how to manage it. Thanks
Posts: 1,441 |
A local junkyard has a 39 or 40 in it and I think it still has a radiator,
VCCA #45194
