I have just begun driving my restored vehicle but with a 6ft frame, I have great difficulty getting my foot on the brake pedal unless I put the gear shift in the neutral position. Any suggestions? Carlyle
If your bench seat moves forward and backwards on the slider mechanism , I have a solution as this is what I do.
I am 6--3 1/2 and my 35 Chevrolet std 3w coupe was very tight and access to the pedals was a large uncomfortable problem.
Solution.......remove the package shelf behind the seat.
Undo the sliding hardware from the floor. Put the seat back in and place it where its most comfortable for driving in the foremost point. Mark it on floor where the seat slider braketry needs to be re attached , in my case was 8" rearward.
White Grease the metal white metal spur gears and metal sliders, plus the part in the rear that the seat slides onto to keep it going straight. If everything is too your satisfaction, ? Cut a new rear package shelf to fit and happy motoring in comfort.
I trust your 32 coupe seat works the same as mine.?????
mike
