Hello, the engine form the 490 get hot, after 5 minutes. I make an new cylinder head gasket, the cylinderhead is ground, i searched for cracks, but the engine get hot. i dont know if the centrifugal pump works fine? Can anybody help me? I`m form Germany. My english isn`t perfect, but I hope you understand what I mean.
HOLZWILLY..................you said " I make a new cylinder head gasket ". Are you say that you actually cut the cylinder head gasket out of something and then installed it........?
pray tell what did you make this head gasket out of ???????
mike
