#388245 04/24/17 05:05 AM
Evening group, starting on my 28 speedster and need to get the bare chassis blasted has anyone got a recommendation in Sydney Australia. Have had quotes from $200 to $500 with out coating , and from past experience some places get all the rust off , others leave those deeper pitted areas with a coat of rust . Ray
RAYCYCLED #388250 04/24/17 08:16 AM
Hi,
I have used Impact Glass beading in Blacktown, always very happy, they have been doing this type of work for years, Romford road I think.
Brian
lachlan31 #388287 04/25/17 04:10 AM
Thanks Brian , do they paint as well, as standard practice ? I'll call tomorrow. Ray
RAYCYCLED #388320 04/25/17 07:25 PM
before you start priming the sand or glass beaded frame. Use a product called a RUST CONVERTER first.
I have no idea what's available in AU.
But if you google it , it will tell you what the product does. Basically converts rust and seals it so you can use conventional primer over top.
mike hood
RAYCYCLED #388336 04/26/17 02:21 AM
HI Ray
They treat it with an acid solution which stops it from rusting and it lasts ages.
Brian
lachlan31 #388438 04/28/17 02:14 AM
Rust convertor is basically phosphoric acid. You still need to get most of the rust off before using it. Otherwise there will still be rust underneath.
