#388168 04/22/17 07:37 PM
Carlyle Offline OP
My speedometer will not work in any forward gear but works in reverse? Is it damaged, installed incorrectly, or has a part missing? Carlyle
Check the speedometer driven gear in your transmission. I ran into this once before and the gear was installed backwards.
Check the speedo cable come out on the left side of the gear box.
If it come out on the right side the speedometer will goes the wrong way.
If the gear set is from a late 4 cylinder instead of early 6 the cable will run backwards.
I agree with Chipper. Do you have another set to compare with?
Carlyle Offline OP
Skip, thanks you for helping Mark Murphy with my speedometer. Carlyle
You bet! Glad to help out.
As Mark discovered after our conversation, the speedometer driven gear was indeed installed backwards.
