Grease Offline OP
Got a question and maybe I read it somewhere. When setting the cam gear to the crank gear should the dots (marks) on each line up? or is the cam gear correctly punched to set the timing?
See your other post for the answer.
There are a bunch of timing gears from that time that are mismarked. It is necessary to count the teeth from the key slot to get the timing correct. It is covered in the May '28 Service News on page 30. The correct mark on the cam gear should be at the 15th tooth counter clockwise from the key slot. The crank gear is directly opposite the key slot between two teeth.
