#387587 04/13/17 11:21 PM
DwFinch Offline OP
When I fill up the gas tank, I get a strong smell of gas in the cab. It gets worst when I go around corners. If I fill it to half full the smell is not there. Is this common?
I would check the connection between the tank fill and the tank. The joint may have gotten hard and caused it to be loose and possibly leak.
Agrin devil
