Posts: 33 |
What does this group use when replacing the vacuum advance line and oil feed line to the valve train?
Aluminum? Brass? Stainless?
Wall thickness?
Thanks,
Jeff
1934 4 Door Master 1927 Runabout truck 1937 1/2 ton truck 1957 Nomad
I use plate steel tubing for fuel and vacuum lines. Use copper for oil line to valve train. Had to find some of the brass fittings. Took a while but finally got them.
Posts: 1,478 |
There are suppliers that have these already made up. The Filling Station and others. Look in Hemmings Motor News .com for a list.
