Posts: 6 |
1947 Chevy car with original 216 and 3 spd. non-overdrive transmission is rough when driving over 45-50 mph. Any idea on potential causes?
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Tire balance would be the first thing I would check.
Along with tire balance old tires could be out-of-round. A general vibration could be the U joint or torque tube drive shaft bushings.
Posts: 127 |
might check the vacuum lines to the vac. advance and the vac. advance diaphragm. blow into the vac. advance and see if it moves. easy to do, cheap to remedy. jim
jf lewis
