I was lucky to find a brand new in the box Air Flow heater for a 1951-1952 passenger car. I mainly wanted it for the heater core for my 1950. Then after thinking it over I remembered I need a heater motor and water control valve also. Not sure if the seal in the valve survived 65 years.
Was interesing the the interior heater ducts are dark gray (high gloss) like the top of the 1951 instrument panel. The 1950 is the dark blue/gray like the top of a 1950 dash. The heater motor, which is visible, is a low gloss black. The heater hoses have not lettering on them. All the hardware , hose clamps, etc. and a new 180 degree thermostat date 1952 is there.
The heater control, three levers and eletrical switch, cables and lever knobs, etc. I can not use because the 1950 is not the same.
They will be for sale for $40 is any one is intrested.
