48rag Offline OP
Need to find the dome light assembly that holds the bulb that mounts on the back top bow of the convertible top. I bought a new len and chrome ring from chev's the 40's but they don't make the assembly anyone have any ideas?
48Rag,
Sure, use your old one or get mike Buller to make you one. All it is is a little square box with a hole drilled in the right side for the wiring to the bulb.
Easy. But not for me. Agrin
Good luck,
BTW: i ain't no sthinkin bully. Agrin
