Posts: 2,306 |
My door panels were reupholstered sometime in the 80's. I am concerned with how poor they fit so might have LeBaron Bonney make me up a new set. I am wondering about the stainless trim pieces on my panels. Did the Master Deluxe have the upper and lower stainless, or was it only on the Special Deluxe? Did the Master Deluxe also have the vinyl brown bottoms? Was the original fabric mohair? I would prefer using the cloth that LeBaron's recommends since it is not as thick as the mohair sample they sent as an alternative choice. What is the quality of LeBaron replacements? Mine are very thick and heavy and held on by screws attached in the original nail slots, so nailing on new panels would not work. I was thinking of using Velcro to hold them in place. Anyone have other suggestions? Thanks, Mike ![[Linked Image from i1321.photobucket.com]](http://i1321.photobucket.com/albums/u560/41chevymike/IMG_0983_zpsoe5k7tef.jpg)
The Master Deluxe has no chrome trim or vinyl at the bottom Just some sewn in horizontal ribs. While the seat material has a slight Heringbone design the side panels are plain and color/materail looks alost like a Special Deluxe, a short nap mohair.
Posts: 2,306 |
Hi Gene,
Thanks for the info. LeBaron wants about $1,600 for a set of panels for the doors and back seat area. Maybe I should put my big boy pants on and do the work myself. Curt Kennedy is doing his interior on a 40 4 door and thinks I should/can do mine.
Was there any stuffing between the fiber board backing material and the fabric? My doors also seem puffy as if the fabric is not glued to the board.
I will post some pictures of my rear seat panels to check with you on their authenticity. I have been trying to refit window garnish and am realizing how much some of it was bent to accommodate the thickness of materials. The garnish I am using is not the Special Deluxe type that was on the car when I bought it but rather garnish from a Master Deluxe.
I have lots of question for my local upholster. I have a June 13th appointment for him to do the headliner and windlace. He is coming over to see my project before I place an order with LeBaron's.
Best wishes, Mike
There was no padding behind the upholstery material. Note there are the sewn ridges with stiching on the door panels but the rear quarter trim is perfectly smooth. Try to find a sampple to follow..
Posts: 2,306 |
Thanks Gene, Here are some pictures of one of my rear panels. The last picture shows the sandwiching of backer boards that have magnified the thickness of the panels to 1/4" on some of the edges. As I said before to accommodate this the bottom of the garnish pieces have been bent, and screws were used to hold the panels in place. I hope someone (Master Deluxe Owner) will post a few pictures of the proper panels, including for the doors. ![[Linked Image from i1321.photobucket.com]](http://i1321.photobucket.com/albums/u560/41chevymike/IMG_0990_zpsg4kwptnh.jpg) ![[Linked Image from i1321.photobucket.com]](http://i1321.photobucket.com/albums/u560/41chevymike/IMG_0993_zpsnuybfvbl.jpg) ![[Linked Image from i1321.photobucket.com]](http://i1321.photobucket.com/albums/u560/41chevymike/IMG_1001_zpsgyho2vds.jpg) Thanks, Mike
Posts: 485 Likes: 3
Posts: 485 Likes: 3 |
Mike it is not a big deal to make these panels yourself. You can buy a roll of whatever color and material to match what you are leaning towards! Plus they sell panel boards that you can trace your old one on, buy some 3M spray foam material glue, and buy a box of nylon door panel retainers so there will be no need for screws anywhere on the panels. You will also need a roll of 1 / 4 inch thick foam or you can use headliner foam to add softness and thickness to your panels! You can buy all of this at www.miamicorp.com Upholstery Fabric - Outdoor Fabric - Upholstery Supplies I myself would not go with LeBaron Bonney unless you have money to burn! Or if you think you could get over your head I would bring it to your local upholstery shop with pics of what you would like the end results for a fraction of the cost of going to LeBaron. Rory 1934 Chevrolet Standard DC Sport Roadster for sale 1933 Ford 3 Window Coupe 1934 Ford 4 Door Sedan under construction 1933 Ford 4 Door Phaeton
Posts: 2,306 |
Hi Rory & Gene, Thanks for the info on doing the job yourself, and for Gene's talk about stitching on the panels. I decided to go through some old pictures to see if I had any of interiors. I found that in 2006 I had attend a Central Region VCCA Meet in Midland, MI and took pictures of a 41 Master Deluxe. The horn button, door garnish (ruby red), kick panel, and front window garnish maybe inaccurate, but you can clearly see the stitching Gene refers to in his above post. If this is accurate I could just have my upholster duplicate the pattern after I cut out the fabric, then do the rest of the work myself. ![[Linked Image from i1321.photobucket.com]](http://i1321.photobucket.com/albums/u560/41chevymike/Mikes%20Cars%20Paul%20084_zpsf9dthgwn.jpg) I appreciate your comments, Thanks, Mike
The top two stitchings are slightly recessed. The lower is a pair of stitchings very recessed and raised in the center. There is also a picture in A Historical Hisory of Chevrolet but no better than what you have. You should have said hellow to me at Midland. Was the last Central Met that I attended.
Posts: 348 |
Mike.... I restored my '41 5 passenger Special Deluxe in the winter of 1999. A friend and I did all the work. I bought most of my parts from Chev0f'40's and club members. I bought a complete upholstery kit from Labonne Barron. Everything fit and looks like it was originally. My car looks like their ad in the G&D. The price for a complete kit is high but it will look good and be the right material. By the time you piece-meal your upholstery you will have a lot of money in the project and it will not match and you probably will not be satisfied. It cost very little more to go first class. Do it right the first time. JIM
Posts: 2,306 |
Hi Jim,
Do you have any interior pictures to show off your restoration?
Thanks, Mike
Posts: 348 |
Mike I will email you some pictures. Have not figured out how to put pictures on CHAT.
Posts: 2,306 |
Here are 2 links to "How to post a picture." Posting Pictures Posting Pictures #2 Good luck, Mike
