#384193 02/17/17 12:25 PM
Ibwild Offline OP
After installing the window regulator spring should the spring tighten in the up direction or vice versa.
Currently mine work to pull the window down when window is all the way closed.
Your spring seems to be reversed, it should offset the weight of the glass making it easier to roll it up.
If you have old Chevrolets, other old Chevrolets will find out where you live.
Ibwild Offline OP
Thanks That's what I thought.
