#383843 02/12/17 12:46 PM
Does anyone know if the 1930 Flywheel Ring Gear (104 teeth 1/2" wide) sold on the filling station, part number WX-104, will work on my flywheel, part number 836218 (104 teeth, 3/4" wide, ~13-3/16 OD)?
Note: I know my flywheel will need ground down to fit it.
Thanks.
Contact Al Suehring @715-677-3809. He specializes in ring gears and probably can tell you if it will fit and also he may have the correct ring gear in stock. www.suehring.com
Thanks for the contact.
Thanks for the additional sites.
