#383705 02/09/17 09:45 PM
Is there a way to remove radiator and water pump from 36 master without taking the grill cowling off?
Thank you,
Daniel
Learning as I go
Daniel
I am not sure about the 36 but for my 38 I would be taking the grille and shell off then removing the radiator form the shell. With that off the car the water pump is very easy to remove. I* think others have taken the radiator out leaving the shell in place but with difficulty.
TONY is correct, safer to remove the rad shell intact and the hood too .
mike........ hood
That is the way to do it. Not enough room for any other removal.
Its not too bad. Its (I think) about 8 bolts to the fenders, 2 to the radiator bottom bracket and two on the rods that come off the firewall and mount to the top of the housing. It fits between the fenders kind of tight --I actually broke one of my headlamp bases because I was lifting with my forearms under these so now I'm out an additional 42 bucks :)
Joel
1936 Chevrolet Master Deluxe 4dr Sedan (Non Trunk)
VCCA 50
Ouch! Hang in there. It is a learning experience.
Hi, unfortunately there is no easy way to remove the radiator. You have to removed the shell and radiator combined.
John
Happy Motoring,
John E.Brayton
Email - johns1936chevy@aol.com
1936 Master Deluxe 2 Dr. Town Sedan
VCCA #41614, - Northern IL Region - HPOCF 2011
*T A for 1936 Master & Standard Cars
VCCA Facebook webmaster - https://www.facebook.com/groups/50230437832/
AACA #4105 HPOF-2006
www.cardomain.com/ride/854810
Thanks everyone!
Learning as I go
