Posts: 194 |
Does anyone know the factory location for the ground strap?
Posts: 2,306 |
Are you referring to the ground strap on the battery? If you are it attaches to the bolt hole on the far left of the flywheel housing. Good luck, Mike ![[Linked Image from i1321.photobucket.com]](http://i1321.photobucket.com/albums/u560/41chevymike/IMG_0847_zpsgdiqdm3t.jpg)
Posts: 194 |
Thanks Mike I thought that is where it went. Just wanted to make sure.
