#383105 02/01/17 11:22 AM
JT1969 Offline OP
hi...I recently accuired my dads 1931 cabriolet...all original..90% complete...im in search of a dash..with or without gauges...also..is floor from the front of the seat forward..wood or metal?....is the fuel line from the tank to the fuel pump available?...and is it the same line as a 1932?...any 1931 chevy parts catalogs available?....I am new to this site forgive all the questions...I am mechanically inclined so no worries with tech chat...this car is an all different animal than I'm used to...also...what type of clamp is used to secure steering column to the dash?....thanx..
Cheers
Jimmy
Hi there and welcome to Chevy Chatter. Glad to have you with us.
The floor (both the floor board and the toe board) between the front seat and the cowl was wood. Those pieces are available from Autowood Restoration in Hanna, Indiana.
For fuel lines, a parts book, and a ton of other parts and literature contact the Filling Station in Lebanon, Oregon. www.fillingstation.com
They also have a hard copy of their catalog available as well.
Good luck with your project!
JT1969 Offline OP
hi...thanx a bunch for the reply...I surely do appreciate it...this Cabriolet is sure a fascinating car lemme tell ya...
JT1969 Offline OP
the fuel line for the '31 in the filling station catalog is on national backorder...there is a place here in Michigan...inline tube...the have a line for the '32...I was just curious if the two are the same...
Here is a site for 1931 Chevrolet run by one of our members. Lots of useful information.
http://1931chevrolet.com/
JT1969 Offline OP
thank you..i found this awhile back...lots of info...helped a lot ...cheers!
In my 31 Cabriolet the steering mast is held by a u bolt with an aluminum surround. I can take a picture and send it via email. On the fuel line I bought a roll from NAPA and formed the new line along side the old one. If yours is missing it would be harder. Try calling Autowood in the morning, seemed the best in getting into them. The floor pieces are nice.
The gas line from the tank to the fuel pump was originally plated steel. The 1931 is the same as 1932. The line from fuel pump to carburetor is the same material but different. The 1931 has an updraft carburetor and 1932 downdraft so the lines are very different.
A steel U-bolt with aluminum cover was used for several years in the early 30s to secure the column to the dash.
In fact the 1931 Cabriolet body is basically the same as 1932 with dash, firewall and a few other differences.
My locally owned auto parts store had all the necessary stuff to fabricate a replacement. You will need an inexpensive tube bender but it is not difficult.
I have a extra dash and steering clamp from 5 window.pm me and we can work something out.
Might have some wood floor pieces also
The dash on a cabriolet is not the same as a coupe due to the cabriolet windshield. You may be able to make one from a coupe dash but it would be a little work.
The dash is shared with the Landau Phaeton...which doesn't make it any easier to find. Seen some on e-bay over the years...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
"The gas line from the tank to the fuel pump was originally plated steel. The 1931 is the same as 1932."
Steve from TFS here. Sorry Chip, I have to disagree with you on this one. Chevrolet changed the routing of the fuel line from 1931 to 1932 passenger cars. The reason was the new cross member and battery tray used on the 1932 chassis.
We have the 1931 & 1932 lines available in both plain steel and stainless - $95.00 & $125.00 respectively. These are special order items and are made to order, sent directly from our supplier to you.
