Posts: 55 |
Would someone pls be able to give me some tips on how to align the doors of my 1935 1/2 ton pickup? thnx Mark in AZ
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
Mark, I will be helpful to know if your truck has original wood, new wood, new wood kit, new wood you made for yourself. If new wood, how did you keep things "square" during assembly, etc. I have not done this myself, but had many conversations with my friend, Roger, during his door fitting period. I will call him and have him look at your post so the two of you can chat.
Posts: 55 |
Yup, I was too vague. My truck is a 1935 1/2 ton with just the original wood in it. The doors sag abt a 1/2". I have tightened the door hinge screws as best I can. There doesn't seem to be much play in the hinges. Just wondering if theres anything I could try to align the doors better. I really dont know much abt the possibliliy of doing doing so. Mark in AZ
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
The hinges should have close to zero play. If you can move the door up and down 1/2" at the lock side when open then I would re-bush the hinges, provided they are tight to the door and pillar.
Posts: 199 |
Hi all, Just my $.02. I assume that if the door wood is original than the rest of the wood is original also, if so, I would consider looking at not just the door hinges but the alignment of the pillars both the front one and rear one to make sure your 1/2 inch isn't the in the surrounding cab wood. I agree, there should be zero movement up and down of the hinge.
Posts: 1,478 |
If you are going to just take the slack out at the hinge then remove the through bolts and place spacers (washers) behind the lower door hinge and the wood. You may also have to "do" the top hinge with less spacers. This will raise the door in the frame. It will also push it (and back) up from the bottom if dragging. Check the wooden spacers under the cab springs that shim the back of the cab on the frame. These often rot out first. Or you can also shim there to "adjust 'level' the cab some" Remember that these cabs were "Hand Made" that they may not be "true". While the through bolts are out check the whole in the wood for wallowing out. If so these may be shimmed with pieces of wood as a temporary repair that will last considerable time.
Posts: 55 |
Thanks gentlemen for the ideas. Mark in AZ
