that's a good size rear window, and because your driving a roadster your close enough to it to be able to see out thru mirror and over the right shoulder to see whats over there.
Your a long way away in a touring and the view out a phaeton is critical..
By the way as a point of interest........the panel between the rumble seat and rear top area , at the corners, plus the area below the rumble lid at the corners. I can see these areas on a north american body are not welded up on the seams like the
Holden body is.
The north American idea is not a good idea IMHO as it allows water infiltration causing rust out of the floors.
mike lynch
