#38127 10/02/06 09:20 AM
Hi guys, I know this sounds stupid, but when installing the okie bushing in a '54 3100, does the end with the oil seal go in first, or should it end up being flush with the end of the driveshaft tube. which means driving the larger opening end, in first? Thanks for the feedback.
Bob
allstate bob
#38128 10/02/06 09:47 AM
The seal end goes in first, the bushing end has to be on the transmission end to suppor the ujoint yoke. The Oakie should be installed so that it is flush with the end of the torque tube. At least that is the way I did it.
#38129 10/02/06 10:35 AM
Thanks Glyn....much appreciated! It's been about two years since I removed everything and the oakie bushing did not come with any detail info. Thanks for your help. Bob
allstate bob
