Chev of the 40's $42.50 or Filling Station $45, anyone with experieance with these babes ?
I bought one of their universal units. It was OK but a bit tight. To fit in the shallow tanks you have to shorten the float arm, a lot. It was so short it didn't want to fall or rise with the fuel level. I made my own float arm, put two floats on it (so it would rise) and a small fishing sinker (so it would fall) on the arm. That worked fine. When I found a good OEM unit on ebay and swapped them out the universal had 'broken in' and the arm moved freely.
If you want one that works , bite the bullet and have your sending unit re- built. hood
p.k.
1956 BEL AIR 2 DOOR HARDTOP
