#380184 12/10/16 11:44 PM
has any body come up with a better idea other than a screwdriver to get dog dish hubcaps off of 50 car i have been using a bondo spreader getting it under the lip and then using a screwdriver between the cap and spreader to pop the cap off there has got to be a better way thanks andy
I use a stiff bent angle putty knife. I have the accessory disc behind the hub cap and they bend easily.
They also make some plastic trim removal tools that may work.
I had the same concern.
I bought a 5 piece "Auto and Molding Tool Set", 5 stout plastic tools, from Harbor Freight for around $9.00.
Specific tools are a wide edge remover, a narrow edge remover, a pull type remover, a handle remover and an upholstery clip remover.
Works fine for hubcaps and trim rings for me, but I don't pull hubcaps every day.
**** Your results may vary ***** is my disclaimer.
Item # 67021. Look at it at Harbor site.
I have been using a brake adjusting tool.
m006840 #380259 12/12/16 04:09 PM
I use the same plastic tools from Harbor Freight. I do have to do some tapping on the end of the tool with a hammer though
