Posts: 1,113 Likes: 1
Posts: 1,113 Likes: 1 |
Has anybody heard of wheel trim rings (shifting) as the wheels move and cutting the valve stems?
I just bought a new set and wonder if I need to slip some rubber hose over the valve stem to prevent this. Maybe I'm over thinking this.
Rick
Posts: 409 |
Hi I have never heard of anyone ever having a problem, mine has them and it would take a tremendous force to make them move at all. Dale
Are you running radial tires?
Hi Gene, Yes, I am running 215/70R15 radials with radial tubes.
Rick
That is what is causing the shifting. The wheel rim is flexing due to being too weak for radial tires, especially one that wide on a comparativly narrow wheel
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I ran 205/75r15 with trim rings and have had no problems.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
years ago, i put a set of radial tires on a 67 corvette coupe that had rally wheels and Original trim rings. i too experienced rotation of the trim rings on the rim. this didn't occur with bias belted tires on the same corvette. mike
Well, they are not shifting as of yet, but I will keep an eye on it. They installed pretty tight.
I have not had other issues running radials, but thanks to all who responded.
Rick
