Posts: 6 |
I need 1 front brake cable for a 35 Master and am wondering if anyone knows a good source for it? Thanks, Dennis
Posts: 44 |
I don't know just what is included, but The Filling Station lists a kit for '35. Here's the link: https://www.fillingstation.com/catalog/flippingbook/index.html#226/z The ones I got for the front on my '33 look good; although I have yet to install them. These would be different from yours I believe. Good luck ;-)
Leaping Lena
Posts: 345 Likes: 1
Posts: 345 Likes: 1 |
have seen 1 front cable advertised on ebay usa,
might be worth a search to see it it`s still on
Posts: 6 |
Thank you for your responses, I found 1 on ebay but I can't get it until Dec 6th to 9th and the customer was hoping to have it in the Christmas parade on Dec 3rd, I guess we can't always get what we want, even the Rolling Stones knew that. Dennis
Posts: 145 |
FYI, there are Right and Left Front Brake Cables for the 1934/35 Masters. They wound the outer jacket CW for one side and CCW for the others side to force the jacket away from the tire on turns. The Left side will have a strand of yarn running the entire length under the outter coil, they should also have a L or R stamped on the brake rod end.
Hope this helps,
Mike B :)
Mike Boteler 1935 Master Technical Advisor
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
My 1941 catalog does not show RH and LH part numbers for '35 Master. It does, however, show different numbers for knee action cars vs. axle cars. I sent Dennis a PM.
Every book I have shows part number 375037 for left and 375038 for right.
Right you are , Gene. I did not make it far enough into the group. I was looking at the pull rod number, not the cable number.
Dennis, I have a cable for you. Call me at 573-592-1991. I can send it today.
