Posts: 26 |
Does anyone know if this head can have valves seats put in?
Posts: 1,284 |
Yes,
Any engine reconditioning shop that works on older engines should be able to replace seats in a Chev 4 head
Regards
Ray
If you want to install seats for unleaded gas you are wasting your money. 90% of the gas sold in the 1930's did not contain lead. It is not necessary.
Posts: 26 |
If you want to install seats for unleaded gas you are wasting your money. 90% of the gas sold in the 1930's did not contain lead. It is not necessary. SO are you saying I dont have to add the lead additive to the gas? The reason I was asking about doing this because the head has at sometime "fixed" with different sized valves and the replacement valves dont fit and are sitting low. So the guy I spoke with today suggested putting in valve seat rings, but he wasnt sure that could be done on this year of head. Also Do you know a machine shop in the area that does valve work? And anyone that works on the honeycomb radiators locally? Thanks Barb
Posts: 1,255 Likes: 10
Posts: 1,255 Likes: 10 |
The replacement seats are a great fix for this problem and should help the engine breath much better. Earlier in the year I reconditioned a head for a 29 6cyl. I was cautioned to be careful not to cut the seats in too deep because the water jacket is very close and there could be some pitting. I would think the casting on the 28 4cyl is similar.
If the exhaust valves are ground(valve seats that is) several times the valves will seat too low and valve seats are a fix. Lead additives are not necessary and do not even contain lead. The valve spring tension is so low in older engines that lead is of no use. Probably would help in a modern high performance racing engine. Same for any oil addatives. Modern 10W-30 oil is 1000 times better than the oils available when the car was new and noting needs to be added to the oil.
Posts: 1,213 |
With the original steel the valves are made from,and the fact that they are seating on hot cast iron seats,in particular the exhaust valves,valve seat regression(wear)can and will occur. As long as the inlet valves don't sit too low below the face of the head,it's only necessary to use valve seat inserts for the exhaust valves,as the inlet valves aren't subjected to the same high temperatures as the exhaust valves. That's why in the days when these cars were new,it was a common occurrence to take the head off every 2-3,000 miles to re-seat the valves and do a de-carbonising job to the poorer burning nature of the petrol available at the time.
CJP'S 29
