#377843 10/30/16 06:26 PM
I installed my cluster today to find that the temp gauge is stuck on hot. Any repair tips? Or does anyone have a replacement available?
Take the bulb (sending unit) out and immerse it in a very cold environment (container of ice and water) and then into very hot water. This treatment makes the assumption the tube or bulb is not comprised.
Agrin devil
Will do. Thanks!!
I put the bulb in a bowl of ice water this morning with no change. Looks like I need a gauge. Anyone??
Did you immediately follow that with the hot water?
IF IT IS STUCK ON TOP IT IS SAFE TO ASSUME IT IS DEAD.
It's dead. I've made arrangements to have the bulb repaired and gauge tested. Thanks
I might have an NOS one if you need it. Send me a PM.
Did he get back with you? Are the 37 and 38 the same I need one for my 37 Master Coupe.
The Honer
The 1937 1938 and 1938 all look diffeerent but will fit in the same opening. Also the Master and Master Deluxe look different.
Mine has the delete with Chevrolet on it. From what I have studied the Master did not have a temp gauge from the factory. But it was offered as a accessory from Chevrolet.
The Honer
Corect,but most had the dealer installed unit. If th head has never have a temp. gauge fitted you will need the bushing that threads into the head.
I sent my gauge off for repair. I would like to use the NOS gauge, but trying to keep my cluster looking consistent as far as fading etc. thanks
