Hi Ho all, just giving my 28 an overhaul after 25 years of use, rebuilt a gearbox and now getting ready to reinstall, but i need to replace the shaft for the brake and clutch pedal, how is it held in to the casting? press fit , may be left hand threaded, one part with the casting? want to be sure i don't butcher something trying to get out out, RAY
Hi Ray,
I believe its a press fit.
Regards
Ray
You have to grind of the bolt and remove the bracket from the housing. Use a heavy press (20 ton or more)
Heating my be needed.
Good luck
Arvid
[Linked Image from i.imgur.com]
Thanks Arvid, photos and all ! RAY
Hi Ray
I sell a brake/clutch pedal shaft kit that comes with the tools for removing the old shaft for 26-30 Chevys. This is made by C&P Auto. The old shaft is drilled and threaded. The bolt and the sleeve are used to pull the old shaft out without removing the bracket from the bell housing. The new shaft is then tapped back in to the bracket. The shaft that comes with the kit is made of moly chrome steel and is drilled and tapped for a grease fitting. We also have the replacement bushings. To check this out, click on this link to our web site http://www.marxparts.com/repro%20chevy_clutch_brake.htm
Regards Bob@marxparts
Hi Bob, all done mate, pressed it out, now I know how they are made wasn't so worried , I have a 10 tonne press, turned it down to 11/16" reinstalled and put in an 11/16-13/16" bush and ready to bolt in tomorrow sand blasted and painted the pedals and rods seeing as its 30 years since they were down by my dad, I'll post. A pic or 2 in the morning. Ray
