#378194 11/05/16 12:46 PM
pottejo Offline OP
Does any one know of someone that has a boot for the 31 or 32 Cabriolet. I'd like to be able the cover the top when it's folded down. Not sure where the fasteners go.
I just had one made and they designed it so two straps flow under the top from rear to front then snap on the front side. They also made a flap attached to the top front that tucks under the bottom front. I'm not sure if it is "original correct" but it works great.
31 Chevy Roadster
64 Corvette
76 Corvette
77 Grand Prix
pottejo Offline OP
Do you have any photos you could send me? I'd like to share them with my Upholster. This is, at least be one solution to the problem.
Does anyone know if this is how the boots were originally installed?
jelwpotter@hotmail.com
I've stored it for winter but let me try to put the boot on and get some pics for you. I can also give you the name and number of the upholster guy I used and he could likely make one using mine as a pattern.
31 Chevy Roadster
64 Corvette
76 Corvette
77 Grand Prix
I just sent you an email with five pictures in it. I hope they will help you.
31 Chevy Roadster
64 Corvette
76 Corvette
77 Grand Prix
I'm going to try and duplicate the 32' Oldsmobile DCR boot cover which is essentially the same as a 32' Chevrolet Cabriolet. Does anyone have an original Chevrolet cover or a true duplicate of a Cabriolet boot? I would assume the Olds and Chevy are virtually the same. I do have original factory photos, but no detailed close up ones.
pottejo Offline OP
Could you try sending the photos again. They didn't go through. Did your upholster use any cardboard to stiffen the boot.
John Potter
Jelwpotter@hotmail.com
I just sent you the pictures again in three emails so the attachments were smaller. Let me know if you get them.
31 Chevy Roadster
64 Corvette
76 Corvette
77 Grand Prix
pottejo Offline OP
The photos still didn't go through. Letters should all be lower case.
Call me or send me your e-mail and I'll send a test through.
John (805) 484-0907
Here is my email address cirilli@zoominternet.net
31 Chevy Roadster
64 Corvette
76 Corvette
77 Grand Prix
I tried to get some pics posted here but didn't work. Sorry
31 Chevy Roadster
64 Corvette
76 Corvette
77 Grand Prix
This is for sale on Ebay right now. First time I've ever seen a cabriolet with a boot cover. Were they a factory item, option, or aftermarket addition?
The 32' Olds DCR had a factory cover available. I was trying to post a picture but couldn't. A factory photo can be seen here.
http://i.ebayimg.com/images/a/(KGrHqJ,!hgF!znZK63lBQN7PEnoRw~~/s-l1600.jpg
There is a pretty good factory photo at the GM Photo store of a 31 Cab boot. http://www.gmphotostore.com/Chevrolet-in-the-1930s/products/1305/
The one pictured on eBay looks the same except it is missing the flap over the top of the top brace.
