Got lights working except right side parking light,got ring and glass off easy but reflector does not come off,I do not see and screws ? is there a trick ?? also got heater back in with both motors working OK..
You should have clips as shown below on either side of your reflector. Push the reflector in slightly which will loosen the clip. Remove the clips. You'll also have a brass colored clip on the bottom of the reflector that works with the adjusting mechanism. It just clips to the edge of the reflector so just slip it off the side.
This is what the clips look like removed.
Very good thanks much .. I got them a part changed bulb..they were in good shape for setting so long..still could not fix right parking lite,inside fender connector was hot but at socket nothing..tried to trace out the problem but could not..inside fender wire was hot but inside head lite nothing.wires looked good but must be broken somewhere.kind of strange.
