#377955 11/01/16 01:52 PM
Does anyone have a source for the 1/4-20 truss head carriage bolts for the front fenders for mounting to the fender supports? All help is appreciated.
Check the Filling Station's catalog.
Thanks JYD. I had looked at FS but saw only 10-32 in the rivet head bolts. I need 1/4-20x3/4. Couldn't find at fastenal, McMaster. Looking now at plow bolts but don't know if head is rivet head type nor if available in1/4.
Check out part number AF-115 in their catalog.
The 4 bolts for hold the front fender to fender support are like carriage bolt 1/4 however the head diameter is slighly large. ( head diameter 5/8 head height 1/8 ). You can buy ss carriage bolt 1/4 from Restoration Supply Company Escondido CA or step bolt and make the exact head diameter on a lathe. This bolt are painted like the fender.
duhen #378164 11/04/16 04:12 PM
Jmm Offline
www.Bolts.com
www.Fastenal
Jmm #378172 11/04/16 07:13 PM
Thanks for the info and links. The company in Calif has them (they call them threaded rivets)
