before I destroy something... need to remove front seat bottom cushion also radio delete plate and gauge plate on dash R&R..any tips ?? trying get to the GD fuse without hiring a pigmy..Tnx.. sc
The fasteners all access from behind the dash. You have two, either screws or studs with nuts, to remove the radio plate. It's been a while since I had mine off. I'll go out to the garage and look later if need be. As for the seat I have some pics of the seat in my couple but I don't know if the sedan is the same. Here's one.
the 1938 front seat cushion doesn't come out as you would expect. You have to remove the whole seat. Here is some information from the Manual Of Construction Book
http://chevy.oldcarmanualproject.com/fisher/1937_38/3738fmcs104.html
VCCA Member 51121
Great info..thanks much
