36dlc Offline OP
I have located 2 good 4 cylinder heads and need help with their date codes.
The first head has a date code of D 19 6 - am I correct that this is an April 1926 head?
The second has a date code of 10 2616 ; there is a raised "screw head" impression between the 10 and 2616 an another "screw head" impression at the end after the 6. What does this represent?
Dave Cufr #12505
1927 Capitol coupe
1928 National 4-door
1928 Speedster
1936 Standard Town Sedan
1975 Nova Custom Hatchback
I think the screw heads are casting plugs.
36dlc Offline OP
My question was not about the "screw head" impressions but about interpreting the date code on the second head.
Dave Cufr #12505
1927 Capitol coupe
1928 Speedster
36dlc Offline OP
I just found out that the 10 2616 coded head is a 1916 head with a 407-5 casting number. If anyone is looking for a good 1916 head please PM me.
Dave Cufr #12505
1927 Capitol coupe
1928 Speedster
Dave - I wondered if that was maybe the case. However, a Head cast in late October of 1916 would be for a 1917 Four-Ninety, as the model year changeover was in August. About a month lag between casting date and assembly, so it would have gone onto a car built in late Nov or early Dec of '16, well into the 1917 model year. Of course, someone could also use it on a '16, or an '18.
(The Head was cast 100 years ago on this past Wednesday!)
Chevy Guru
