HPCnerd Offline OP
From time to time my starter will lock-up my engine. This typically happens when my battery is low and apparently does not have enough juice to get my Bendix pinion to spin back from the flywheel. I fix lock-up by removing and reinstalling the starter. Anybody have any suggestions on how to eliminate this lock-up issue? Hopefully there will be suggestions beyond the obvious which is to always have a strong battery. :-)
Check the two bolts that mount the starter. You may also have a 'dragging' starter which needs both bushings.
Agrin devil
Check the splines on the pinion and starter and the bendix spring and bolts.
I had the exact same problem on my 1930. I installed a new Bendix and that did not help. It turned out to be the Battery ground cable was corroded and to small to do the job. There just wasn't enough power to spin the starter fast enough. A new heavy ground strap fixed the problem. Having big enough and clean battery cables is so important.
I had the same issue, and the same solution
if battery is low and can NOT spin starter hard enough to start engine, then bendix gear gets stuck out and have to remove starter and manually spin it back down, then reinstall. then engine spinning and starting up, spins the bending gear back in the starter.
As mentioned above, your starter armature could be dragging on the pole shoes which would also cause the same problem. If that is the case your starter will probably need a complete rebuild, which would also include a new bushing in the nose cone. (Note, that in the 714L model starter there is only one bushing, not two).
Looking in the Filling Station online catalogue they only show a starter bushing commutator end, part #AF-40. Where can you get the nose cone bushing?
Paul
If it isn't broken, fiddle with it anyway so you have something to repair.
1931 Deluxe Sport Roadster
1953 BelAir 4 dr. Sedan
1965 Chevy II Nova SS
The Filling Station catalog is in error. There is no bushing used in the commutator end housing from the factory. The only bushing used for the 1931 starter is in the nose cone.
You can get the correct nose cone bushing on the Internet or from your local starter shop.
Billy Possum has a newly manufactured Bendix Drive. Works great for those problem starters.
http://www.billypossum.com/c&p_catalog/c&p_catalog_rev_031225.htm
1925-1934 Heavy Duty Bendix Drive Assembly with Spring. These heavy duty starter drives differ only slightly from the original in that they have a spring that is less likely to break. Also an improvement has been made in the way the drive gear is returned. p/n 342793 … $59.25
My Chevy is over 70 years old and still running great. I hope I keep running cuz I just turned 81 !!
Years ago, my uncle had a Model A which would do the same thing. His solution, if he were stuck somewhere away from home, was to put the pickup in third and give it enough of a shove to nudge the engine. This would usually work to free up the pinion in an emergency.
I've had this happen as well. You don't have to take the starter off. You can put the crank in the crank hole and manually free the engine. Make sure the car is in neutral!
Youth is wasted on the young
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
When mine got stuck, I would put it in 3rd gear, and go to the front of the car. Then by pushing on the radiator, I'd "rock" the car a little bit. That frequently got the pinion to snap back and then let me try the starter again.
iagree I haven't had this happen for years but that is what I did and it worked!
Ed
My car's like me, it doesn't like getting pushed around and it's always pretty cranky so I stick with the hand crank.
HPCnerd Offline OP
Thanks for all your suggestions these are great! My grandfather rebuilt the starter so I will assume for now it is mechanically sound. Putting it in third gear and giving it a push is a great idea. Now I have less concern that the starter will stranding me while I am out on the town!
Please don't use the phrase "go to the front and push on the RADIATOR", that is how many radiators get dented as the radiator material is very soft and easy to dent.
Agrin devil
i had a similar starter problem: severe drag and consequent battery drain. cause: a warn starter bushing that cocked the engaging angle to the ring gear. starter rebuild at Acme Electric (seattle) solved the problem although we did suffer some ring gear tooth damage; chose to ignore that for now. pax, jim '30 coupe
jf lewis
There's a guy here in Tallahassee who fixes ring gears for Chevys. He did my '31 and it's been fine ever since.
You can get a new flywheel ring gear from the Filling Station for $79.50.
I had the same issue. The starter was not pulling back from the ring gear. When i checked the teeth on the ring gear, there was a burr on a number of the teeth holding the starter gear from pulling back. I filed the ring gear to get rid of all the burrs, and now it works wonderfully.
