#377171 10/19/16 05:42 PM
Hello
I'm looking for or does anyone know where I can find rear brake cam bracket for a 34-35 1/2 ton truck. Its the part that hooks to the brake cable and has the adjustment nut on the back. I do have the pivot rod that spreads the brake shoes.
Thank you.
I believe you are asking about part 366006 rear service brake LEVER which fits 30-35 cars and the 1/2 ton trucks. Can you please confirm this so the right part is searched.
Yes Thanks Steve that is the part I need.
Seeing that they fit a wide range of vehicles hopefully someone closer to you will have one or two. If you don't find what you need in the next few days I will check to see what I have this weekend. Well I took a quick look and got lucky and found some that have been cleaned and look good. I can sell them to you for $25.00 plus shipping. If that works send me a PM with your address and I'll drop them in the mail.
