#376640 10/09/16 10:58 PM
rjp Offline OP
Is there any other years that are interchangable with a 25 that will fit with not much pain? Working on the dash.
rjp #376641 10/09/16 11:36 PM
Hi,
I tried to send you a PM, but web site says that you have too many PMs.
I sent you an email instead.
Dean
rjp #376794 10/13/16 08:46 AM
1926 is the same.
Only difference I have been able to find is the early '25's have nickeled brass instrument surrounds, and the late '25's and all '26 used aluuminium.
rjp #376940 10/15/16 01:35 PM
What body style are you working on?
I believe the Fisher body dash is different than the Chevrolet dash.
On both of my late 1925s the gauges are nickel plated brass.
Roger
rjp #376973 10/16/16 07:34 AM
Interesting. Will not argue with that.
A good example of the Chev Superior parts mix up that confuses us all to the point that I doubt anyone knows for sure when some of these differences were introduced, as many seem to overlap. As Alfred Sloan said "our biggest problem all through that era was being able to produce enough of everything" Therefore there may have been several suppliers of these bits made from different materials etc.And of course parts may have been interchanged in the course of the years since.
Fischer bodies? Oops, I had better be quiet. We only had Holden built tourers apart from the rare import.
