Posts: 168 |
Will the above hubcaps fit on a 48 thru 53 15 inch rim with clips? Appreciate a quick response as I'm here at Hershey and I don't want to buy anything more that I can't use. thanks for your prompt response.
The 1937 hub cap is 3/4" inch smaller that the 1940-1948 hub cap.....but I am 95% sure they will fit the later wheel.
Posts: 168 |
Thank you for your Divine guidance and leadership, and prompt response
you may not be so happy if they don't fit.
