Hi, have a delco stereo older 70-80 am/fm radio 8trk. 16009960. problem- don't know where to hook up most of the wires. this was bought on ebay, used. 1 wire in the blk plug for lamp in dash. where does it go. the other plugs are for the spkrs. also, where does the 8 trk get power. i see no plug for that. how hot should radio be to the touch. i tried bench testing and the sound is low or none and the radio was hot to touch on left side area. the spkrs are 4ohm to 8ohm, do i need 10ohms? i only need 2 front spkrs. is the radio ok. thanks in advance for any help frankyt
