Can I replace a 1936 Chevrolet Standard transmission with the transmission from a Master without changing the bell housing or torque tube? (Here's why.)
If I can, would I be better off to search for the Toledo transmission or the Warner transmission?
Thanks!
Eight for show, six to GOW!
Have you visted us in the speedster forum?
The bell housing would be the same. The problem is at the rear like length, U joint, splines, etc.
The Warner Chevrolet used in 1935 and 1936 due to a strike was for Master models only.
The bolt pattern at the front is different and you will need a master bell housing. As for the torque tube etc, nothing will match up without a lot of machining. It can be done and I have seen it done but it is not a bolt up operation.
The bell housing is not the same.
Thanks fellas. I'll stick with the Standard trans--just gotta find a shift lever.
David, I sent you a PM.
