#375277 09/12/16 10:30 AM
My parts book dtd Aug 32 says there is a shim under the rear crossmember cover (gas tank apron?). Any one know what size or type material? Also location of the shim? All assistance appreciated.
First thing you need to ask yourself is WHY is a shim needed.
An examination of the gas tank cover too the rear frame cross member with the panel not sitting PERFECTLY flat , against all the mating surfaces, would be the primary reason for a shim.
Basically if your trying to snug the panel down you want it to be resting flat, otherwise your going to bend or distort the panel . Just common sense
mike lynch Agrin
The (shim ) is used to provide a buffer between the gas tank cover and the frame. There is also a strip of material on the top of the gas tank . Probably for an anti squeek and to prevent metal to metal contact . The stuff I removed looked like heavy roofing material .
On the sides of the cover there are two spots where the rear fenders bolt to the gas tank cover . The fender welting is sandwiched in between on both sides . Hope this helps .
My 32 had some roofing felt on top of the tank...I used a small piece when we replaced the tank....Fitted up very well...
Mac
Many thanks for those reasonable answer.
I'm aware of the purpose and reason of a shim, didn't know material and location. Thanks
Jack, what size fender welt did you use? Mine had no welt at all ( except the remains in some areas between the metal). Any ideas as to the size of the shim? Thanks again for your input.
I used 3/16 inch welting ,purchased from Steele rubber, The gas tank shim I used was rolled roofing .maybe 1/8th thick .
Thanks for the info, that's what I'll do.
I used aptly the same that Jack mentioned...Welting is excellent....I used just a log piece of the felt....8 inches wide by 20 inches long....
Mac
Thanks Mac, that was going to be my next question (size). Ya'll have most helpful.
