Posts: 282 Likes: 2
Posts: 282 Likes: 2 |
Just checking, need to install a gas line for a 28 speedster. Any pros or cons of copper versus steel brake line tubing?
Mike Quezada (559) 250-5427 mike.quezada@M2ProSol.com
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
I would use steel brake line material. Copper will work harden from vibration and crack.
Joined VCCA June 1, 1961
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Steel is best. Copper can become brittle and break. There is a product that is a copperized steel with zinc outer coating. It withstands up to 3000 psi and is fairly easy to bend or flare. Check with your local automotive supplier or JEGS on line.
Posts: 1,284 |
Have had copper for 43 years no drama.
Cheers
Ray
Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
 When I bought my '33 coupe as a basket case in 1979 it had a copper fuel line, no problems so far! ??
Ed
Posts: 935 Likes: 12
Posts: 935 Likes: 12 |
In my humble opinion there is a difference between using copper on fuel lines where there is very little pressure vs copper on brake lines where there is much greater pressure when braking.
Dick
Dick
Ed
Posts: 88 |
I have had copper fuel line in my '25 for 40 years with no problems, despite the fact it can work harden. This usually causes problems only in the line that runs from the vacuum tank to carburettor. A full circular loop usually fixes this by allowing the tube to flex without work hardening and is a common sight. Steel is always a problem with rust forming over time, and I am sure car makers use it only because it is cheap.
I have seen copper plated steel tubing.
Posts: 282 Likes: 2
Done, it was nice not having to straighten out the copper line to make it straight, but a little more difficult to bend.
Looks great. The brake line that I used had an industrial green/gray finish to the surface.
