There is a center fender support that mounts on the front cross member (uses 3/8 carriage bolts) and the crank hole support mounts on top of it. Does anyone know if it has any type of anti squeak or cushion goes between the support and frame? The radiator assembly will sit on top of it when installed. I assume the radiator mounting pads will go between the radiator and the center support? Hope I have explained it correctly.
Page 55 of the 1932 engineering specifications describes the fender supports as sitting on an insulated cushion, It shows a drawing of the joint , which looks to have a cushion approx. 1/4 inch thick.
JACK
The above is on page 55 of the 1932 Chevrolet "Engineering Features", not the "Engineering Specifications". The "Specifications" manual is a different manual than "Engineering Features" manual.
Thanks JYD, I think I have a copy. Might not have gone far enough in it.
The specifications for this cushion ( # 367314 ) is 1 1/2" x 4" x 3/16". For make this cushion l prefer materiel as conveyor belt which is rubber-coated fabric and not just rubber.
Thanks for the info.
