#374776 09/03/16 02:23 PM
pottejo Offline OP
Does anyone know where you can buy a pre-bent fuel line for a 34 master. It would be nice to find something I don't have to splice together.
pottejo #374778 09/03/16 03:15 PM
You can make one yourself out of steel tubing using a small tubing bender that is available from any tool supplier. I made mine for my 1930 and it is identical to the original, and it wasn't that difficult to do.
There is a new material available at most parts stores that
is steel appearing on the outside but with an alloy lining in the inside that makes it much easier to work with. You can
easily bend it by hand into most common curves and it can be
flared conventionally, yet it has sufficient strength to be safely used even for brake lines. I suggest you try to remove
your original to use as a model for the replacement. With a little patience it should not be too difficult to achieve good results! I made the line from the fuel pump to the carburetor easily, and it looks totally original!
flip
pottejo #374817 09/04/16 12:31 PM
pottejo Offline OP
I was afraid I'd have to make my own. Thanks for the tip about the new material. I'll look into it.
pottejo #374828 09/04/16 04:56 PM
John,
I have made several fuel lines using 5/16" steel brake tubing. Not nearly as hard as you might think if you have a decent pattern. The pattern does not have to be perfect just fairly close. Adjustments can be made to fit. I suggest leaving both ends a tad long. They can be cut off later.
Chipper #374831 09/04/16 08:35 PM
I found a guy in my town that builds street rods. He sold me a 21' (I think) section of unpolished stainless. Bent real nice just keeping your thumbs together. Thumbs were sore for a while. The tube for the vacuum advance I bought from Grainger. Build the carb line first & then the vacuum tube. All looks good & clean. Like Chipper says, make them too long to start with & shorten when everything is where it's supposed to be....Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
