Posts: 43 |
Question, will a 1939 Chevy passenger car steering box fit a 1947 Chevy passenger car?
Posts: 2,306 |
What is wrong with your current box?
Good luck, MIke
Posts: 43 |
Leaks , took most play out. Would like to have one to rebuild. Filled mine with corn head grease. So far so good. Have a friend with a very good 1939 box , but don't know if compatible.
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
The housing and pitman shaft are the same. The worm shaft and steering column are different due to length.
Posts: 2,306 |
We have covered this topic many times. Have you searched previous posts for alternate causes for steering issues? Here is a sample of postings Steering Box Adjustments. Good luck, Mike
Posts: 96 |
I've got a 48 in my 39 MDSS. Works fine, just a slight difference in mast length. Mine is is RHD though, LHD may be different. The different length made no difference to the column change. Went on fine.
ColinGrant
