You don't say the method of measuring a rim that you are used to. Chips method will work great. Another way of describing his method is that if you measure between the SHOULDERS of the rim in both directions ie width and diameter taking into consideration the thicKness of the rims metal that will give you the more modern size. If you are used to the older type of dimensions a 3" X 21" 1928 rim would be sized 33 X 6. You double the second number and subtract that from the first. A 1927 and earlier 2-1/2" X 21" rim would be 31 X 5, a 1929 3" X 20" rim would be 32 X 6. I still find it rather confusing and awkward to do the math, but it is a must if you are going to be working with brass era cars.
