#373535 08/11/16 01:57 PM
Rivard Offline OP
I am getting spark outside the engine. The rod at the spark advance plate is sparking. I am able to get the car to idle but has no power to move it. I have a new reman distributor with the old internals. Not sure if it is correct but I installed everything the way I took it out. Both sides of the points stay grounded all the time. I open the points and check continuity and it shows it is still grounded. Is that correct. Very confused. Paul
Rivard #373538 08/11/16 03:56 PM
The movable arm of the points should not be grounded when the points are open.
Ed
Ed_Osier #373720 08/15/16 12:17 PM
Rivard Offline OP
I agree. I just don't know what is wrong with the distributor that is keeping if positively charged. I need to find out what insulated parts are inside the distributor so I can keep it isolated when it needs to be
Rivard #374244 08/23/16 12:13 PM
Could the brass wire holder that screws in be grounding to the body of the distributor? or as suggested it the points.
