Posts: 2 |
Hey there all ! I'm starting to research an old 216ci motor in my 52 pick up.I'm finally going to get into this project that has been siting in my yard for 8 years .Wanted to start with getting her in good running condition ,and rebuilding the engine to start. I've never been in an engine this old , and I'm hearing alot of opinions ,but mostly change that motor ,or don't mess with those babbit bearings both of which I say- balonie ! Right?? Any way I hear babbits need to go to a machinist but i've also heard they're convertible or serviceable ? Ive been a mechanic for 19 years,10 with Chevrolet ,and need a heads up on what I'm getting into .Any info would be appreciated . Thanks in advance , Tony
Hi Tony, If you have been a mechanic for 19 years, we should be asking you questions. Seriously, if you have not actually worked with these older machines they are sometimes a challenge. However with mechanical experience and this site you will be just fine.
If the present bearings and crankshaft are in good condition the bearings will only require adjusting.This is done easily by removing shims.All bearings are "babbit"-replaceable or not.The old 216 rods had the babbit "attached" to the rod it self and not to a shell.If necessary and/or desired, or if the crankshaft needs turning, converted insert type rods can be installed.The original 1948-53 rods had the thinner babbit, not to be confused with the earlier engines that had rather thick babbit layer.If you don't have one get a shop manual.The adjusting process is well described for the rod and main bearings.
Posts: 3 |
Go to www.inliners.com at the top of the page you will see an ad for Beck's Machine and Tool click on this site, his shop is not very far from you.
Posts: 2 |
Thanks to all that replied ,I'm new to this site ,so hope this was the proper procedure to get the thanks out.
Posts: 4,951 |
Teespan, You did as well as any and better than many. I'm definitely not one of the 'experts.' But there are a number of them in here. It's really a good place to ask questions. And get good answers. I am aware most of the fellas appreciate hearing back. Sort of let's them know the one asking the question(s) actually took the time to read the "answer(s)." As they say, "You 'done' good." Bill.
Posts: 619 |
Tony, I too am an old dealership technician. And like you, was a bit cautious about opening up one of these old engines at first. I never even heard of a babbit bearing? Like Gene stated, get the shop manual! When you read it, you will marvel in the beauty of the simplicity that these engines were designed. It truly is fascinating reading. After so many years of building these modern engines for work, it kind of took the fun out out of it. After you dive into your 216, you will re-discover the joy that made us choose this field when we were kids. The guys on this board are the BEST you will find.
GOOD LUCK, and ENJOY...
Posts: 6 |
I also have a 52 pickup I bought 7 years ago with the original 216 which had been sitting for years. I took it to a good mechanic because I assumed it would need a rebuild. After cleaning 4" of sludge from the pan, valve adjustment and a rebuilt carb, he said there is nothing wrong with it. Just drive it. Those old motors are tough.
