#37364 12/27/05 04:39 PM
im posting here because i belive the fellow that sold me a transmission for my 51 pickup sold me a car transmission. The #s are 3686832 gm.Im hopeing some one can tell me exactly what i have. thanks Ron.
1942 1/2 Ton. 1951 1/2 Ton. 59 cushman scooter.1960 biscayne Sedan. 1966 c/30 motorhome http://community.webshots.com/user/ratmann1
#37365 12/27/05 06:05 PM
Also will this work in a truck?The only differences i see are that this one is slighty shorter than the one i pulled and it doesnt have the boltholes for a master cylender although they are not needed on a 51 truck.Thanks Ron
#37366 12/27/05 07:02 PM
The number you give 3686832 is for the side cover and that fits 48-54 ALL (3-speed) exc FK, FJ. The transmission case casting number should be 5916115 and fits 48-54 comm. 3 spd.
Check your case for casting number and casting date.
Walt D
1934 Mstr 4 dr/sidemnts
1937 1/2 ton P/U
1953 Bel Air HT
1946 Aeronca 7-AC Champ
#37367 12/27/05 07:05 PM
Correction on the info I gave you the casting # is 591615 for the transmission case. I put one too many ones and one is enough!!!
Walt D
1937 1/2 ton P/U
1953 Bel Air HT
#37368 12/27/05 09:51 PM
Walt D,after a litle more work with a wire brush i found the 591615 on the case.Thanks for positivly identifying it for me.With a little luck and some rush orderd retaining clips i should be back on the road by the weekend.Thankyou Ron.
