Old216,
You may consider the fix that Ihave invented for my 41.
a. I took the drums off.
b. I took the windshield wipers off.
c. I bought new windsheild wipers.
d. I installed the new windshield wipers.
e. I cut the old windshield wipers into lengths equal to width of the brake drums.
f. I super glued the windshield wiper lengths to the leading edge of the brake shoes so that there is but one ten thousands of clearance between them and the drums. I cocked the lengths about twenty degrees to the outside in order to help in clearing the water from off the drums. Sort of like a road grader blade.
g. Now when there is any percipitation anywhere from a mist to a downpour I merely touch the brakes now and then and the wiper lengths will wiper the drums thus affording a clean dry surface for the shoes. You can stop almost as fast as you would picking up a hitchhiking blonde in the Mohave Desert.
When raining, I also pull up on the parking brake just enough so that the lengths are constantly but just slightly touching the drums. (Naturally, you can't do this for the front drums.)
The above system works very well unless the water is up above the bottom of the drums. Then there is just too much water. It is too deep, you see.
I plan on appling for a patton for my invention. Soon you all will have to pay me for this here super effective invention. But right now you can do the job for free. You're welcome.
Good luck,
Charlie
BTW: Owing to Canada being the most literate country in the world, I'm surprised you haven't figured out the above solution befor I did. Go figure.
BTW2: I suppose I should point out that I am merely kidding about my invention. You can't assume that those members over in Morganton and Asheville, NC will not understand my post and go right ahead and try this so-called invention.
